Spanish Heel Gap
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=6244
Author:  dubell [ Wed Apr 19, 2006 6:31 am ]
I am making my second Classical with a Spanish Heel. During my first, I cut the headblock to wide (about 1/64”) and had to shim the sides to close the gap between the sides and heel. I made note of this so I could be sure that I wouldn’t repeat this mistake again.
We’ll that failed. Last night while drum sanding my sides, I went too far. I was too concerned with thicknessing to .080”.
What do you recommend for shimming or closing the gap at construction time? Or, what is another procedure?
Author:  Rick Turner [ Wed Apr 19, 2006 10:35 am ]
Why not do the tapered slot style and put in tapered shims to get that joint perfectly tight?   It's structurally better, anyway.
Author:  dubell [ Wed Apr 19, 2006 11:57 am ]
What is the tapered slot style?
Author:  CarltonM [ Thu Apr 20, 2006 5:31 am ]
Doug,
First, a disclaimer that I haven't done this myself, but this is the process that I've seen and read about...
Cut the heel side of your slot as normal, then enlarge it by making a wedge-shaped cut (doesn't have to be very large) that tapers to the end of your first cut. You can then insert your sides and use the cut-out wedge to hold them flush with your heel (you'll probably have to do some sanding on the wedge to get a tight fit). You'll want the wedge to fit pretty much flush to its original spot in the block. People who have done this a lot can fit the sides and wedge so well that glue isn't needed, but that sure would make me nervous! Make a few practice cuts on some junk wood of the same dimensions as your neck block, and test-fit your sides 'til you're comfortable with the process. Remember, if you're not practicing on scrap, you're practicing on your guitar!
Author:  John Elshaw [ Thu Apr 20, 2006 6:06 am ]
[QUOTE=CarltonM] Doug,
People who have done this a lot can fit the sides and wedge so well that glue isn't needed [/QUOTE]
I think most people who build a Spanish heel don't glue the sides in, whether they're using a wedge or not. What do the rest of you do?
Author:  jfrench [ Thu Apr 20, 2006 6:29 am ]
I do the wedge and glue it in. But no glue between sides and the neck heel. Only glue the wedge to the sides and foot.
I forgot to use glue on one, and its held up perfectly with just well fit wedges.
Author:  rlabbe [ Thu Apr 20, 2006 6:54 am ]
The slot can be parallel. Just use two wedges to fill the slot. That makes it super easy, because you can just make 1 wedge, then cut it in half lengthwise, and turn one side around. You are guaranteed that the backs will be parallel.
